configure eaps shared-port link-id
configure eaps shared-port ports link-id id
Description
Configures the link ID of the shared port.
Syntax Description
ports Specifies the port number of the common link port.
id Specifies the link ID of the port. The link ID range is 1 to 65535.
Default
N/A.
Usage Guidelines
Each common link in the EAPS network must have a unique link ID. The controller and partner shared ports belonging to the same common link must have matching link IDs. No other instance in the network should have that link ID.
If you have multiple adjacent common links, we recommend that you configure the link IDs in ascending order of adjacency. For example, if you have an EAPS configuration with three adjacent common links, moving from left to right of the topology, configure the link IDs from the lowest to the highest value.
The following command configures the EAPS shared port 1:1 to have a link ID of 1.
configure eaps shared-port 1:1 link-id 1
This command was first available in ExtremeXOS 11.1.
Platform Availability
This command is available on all platforms with the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and what licenses are appropriate for this feature, see the Switch Engine v33.1.1 Licensing Guide document.
